跳转到主内容
Kyocera Marbl K127 Headphone Jack Replacement
你所需要的
  1. Kyocera Marbl K127 Headphone Jack Replacement, Remove the cover on the back of the phone.: 步骤 1 中的图像 1,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the cover on the back of the phone.: 步骤 1 中的图像 2,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the cover on the back of the phone.: 步骤 1 中的图像 3,3
    • Place your thumbs on the pack of the phone and slide them in a downward motion to remove the cover.
  2. Kyocera Marbl K127 Headphone Jack Replacement, Remove the battery: 步骤 2 中的图像 1,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the battery: 步骤 2 中的图像 2,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the battery: 步骤 2 中的图像 3,3
    • Use your index finger at the top of the battery and pull it towards your body.
  3. Kyocera Marbl K127 Headphone Jack Replacement, Remove the phone backing.: 步骤 3 中的图像 1,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the phone backing.: 步骤 3 中的图像 2,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove the phone backing.: 步骤 3 中的图像 3,3
    • Use the Y1 tri-wing screwdriver to remove the four 2.4mm screws and then pry the entire backing off of the phone including the black clip attached to the top of the motherboard.
  4. Kyocera Marbl K127 Headphone Jack Replacement, Remove existing headphone jack.: 步骤 4 中的图像 1,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove existing headphone jack.: 步骤 4 中的图像 2,3 Kyocera Marbl K127 Headphone Jack Replacement, Remove existing headphone jack.: 步骤 4 中的图像 3,3
    • Locate the headphone jack attached to the top right of the motherboard and pull it off using your thumb and index fingers.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 461
