跳转到主内容
Kyocera Hydro Vibe SIM Card Replacement
你所需要的
  1. Kyocera Hydro Vibe SIM Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe SIM Card Replacement: 步骤 2 中的图像 1,3 Kyocera Hydro Vibe SIM Card Replacement: 步骤 2 中的图像 2,3 Kyocera Hydro Vibe SIM Card Replacement: 步骤 2 中的图像 3,3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe SIM Card Replacement, SIM Card: 步骤 3 中的图像 1,1
    • Locate the SIM card indicated by the arrows and picture.
  4. Kyocera Hydro Vibe SIM Card Replacement: 步骤 4 中的图像 1,2 Kyocera Hydro Vibe SIM Card Replacement: 步骤 4 中的图像 2,2
    • Use the precision tweezer set to safely remove the SIM card.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 630
