简介
Sometimes the lock button gets stuck and needs to be replaced this guide will show you how to replace/ fix it.
你所需要的
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
Once you have taken the trim apart, the lock button will be easily removable.
The lock button is located on the top of the phone.
Take the tweezers and remove the lock button.
即将完成!
结论
