跳转到主内容
Kyocera Hydro Vibe Headphone Jack Replacement
你所需要的
  1. Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,3 Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,3 Kyocera Hydro Vibe Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 3,3
    • Pop the back plate off by using your hands or a spudger.
  2. Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 2 中的图像 1,3 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 2 中的图像 2,3 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Remove the trim from the phone by carefully prying it away using your hands.
  3. Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 3 中的图像 1,2 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  4. Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 4 中的图像 1,3 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 4 中的图像 2,3 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case.
  5. Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 5 中的图像 1,2 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Remove the inner plate from the phone using the spudger or your fingers.
  6. Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 6 中的图像 1,3 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 6 中的图像 2,3 Kyocera Hydro Vibe Headphone Jack Replacement: 步骤 6 中的图像 3,3
    • Remove the headphone jack using the spudger to push down on the jack to dislodge it from the phone.
    • Once the headphone jack is dislodged, you can disconnect the ribbon cable by carefully pulling it out.
结论
另外一个人完成了本指南。
Katherine Pfeiffer
于11/01/18注册
154 声望
撰写一个指南
团队
IUPUI, Team S3-G6, Harley Fall 2018 IUPUI, Team S3-G6, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 243
