跳转到主内容
Kyocera Hydro Life SD Card Replacement
你所需要的
  1. Kyocera Hydro Life SD Card Replacement, SD Card: 步骤 1 中的图像 1,2 Kyocera Hydro Life SD Card Replacement, SD Card: 步骤 1 中的图像 2,2
    • Open the back of the phone by prying the back cover off.
  2. Kyocera Hydro Life SD Card Replacement: 步骤 2 中的图像 1,2 Kyocera Hydro Life SD Card Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pulling up on the end.
  3. Kyocera Hydro Life SD Card Replacement: 步骤 3 中的图像 1,1
    • Remove the SD Card by pushing in slightly and then releasing, allowing the card to slide out slightly and then removing it.
    • Place a new SD Card into this slot, making sure to line up the metal prongs.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 194
