跳转到主内容
Kyocera Hydro Life Rear-Facing Camera Replacement
你所需要的
  1. Kyocera Hydro Life Rear-Facing Camera Replacement, Rear-Facing Camera: 步骤 1 中的图像 1,1
    • Flip the phone so that the screen is facing down.
    • Gently remove the back cover with the grip at the bottom of the phone.
  2. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 2 中的图像 1,3 Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 2 中的图像 2,3 Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Use the tab marked "PULL" to remove the battery from its enclosure.
  3. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 3 中的图像 1,2 Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Remove the six Phillips #00 screws from the back of the enclosure.
    • Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
  4. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the white sticker.
  5. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 5 中的图像 1,2 Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Using a pair of pliers, gently pry open the camera ribbon slot.
    • This will not take much pressure to open.
  6. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 6 中的图像 1,1
    • Gently remove the camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  7. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 7 中的图像 1,2 Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
    • Lift the motherboard away from the phone enclosure.
  8. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 8 中的图像 1,1
    • Remove the black sticker.
    • Be careful when removing the sticker. The sticker will need to be replaced after replacing the camera.
  9. Kyocera Hydro Life Rear-Facing Camera Replacement: 步骤 9 中的图像 1,1
    • Remove the camera from the motherboard.
    • This step requires breaking metal.
    • Only cut along the camera square.
结论
Morgan Marshall
于09/21/18注册
277 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 201
