跳转到主内容
Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: 步骤 1 中的图像 1,3 Kyocera Event MicroSD Card Replacement, Battery: 步骤 1 中的图像 2,3 Kyocera Event MicroSD Card Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: 步骤 2 中的图像 1,1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: 步骤 3 中的图像 1,1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: 步骤 4 中的图像 1,2 Kyocera Event MicroSD Card Replacement, Open slot and remove card: 步骤 4 中的图像 2,2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
结论
另外一个人完成了本指南。
graysonmensah
于02/13/15注册
22 声望
撰写一个指南
团队
Ohio State, Team 1-4, Michaels Spring 2015 Ohio State, Team 1-4, Michaels Spring 2015 的会员
OSU-MICHAELS-S15S1G4
3 名成员
创作了4篇指南
3条评论
That's the micro SD slot. That's not for a SIM card.
Carl Jr - 回复
What if there's no metal cover?
Michael ansley - 回复
That's for the sd card not the sim card
gasparesparza9 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,043
