跳转到主内容
加入维修社区 - 创建账户
Kyocera Event Camera Lens Replacement
你所需要的
  1. Kyocera Event Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 1,3 Kyocera Event Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 2,3 Kyocera Event Camera Lens Replacement, Camera Lens: 步骤 1 中的图像 3,3
    • Flip phone over and remove back cover
  2. Kyocera Event Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Use the screwdriver with the Y0 bit attached to take out the seven 5mm screws that attach the back cover on the phone. Make sure to keep track of these screws, as they are pretty important.
  3. Kyocera Event Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Next, use the metal spudger to pry at the plastic clips. Be careful to not to lose the power button and volume buttons as they fall out. Remove the plug for the camera flash.
  4. Kyocera Event Camera Lens Replacement: 步骤 4 中的图像 1,3 Kyocera Event Camera Lens Replacement: 步骤 4 中的图像 2,3 Kyocera Event Camera Lens Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to pry the camera lens and remove it from the rear frame. Then you can replace the lens.
结论
ryan
于03/16/15注册
221 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,579
