跳转到主内容
Kyocera Echo Camera Replacement
你所需要的
  1. Kyocera Echo Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Camera Replacement: 步骤 2 中的图像 1,1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Camera Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Camera Replacement: 步骤 5 中的图像 1,1
    • Unscrew two 4.8mm Y000 screws.
  6. Kyocera Echo Camera Replacement: 步骤 6 中的图像 1,2 Kyocera Echo Camera Replacement: 步骤 6 中的图像 2,2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Camera Replacement: 步骤 7 中的图像 1,2 Kyocera Echo Camera Replacement: 步骤 7 中的图像 2,2
    • Wedge a plastic opening tool under the bottom of the circuit board and push upward to separate the circuit board from the back of the phone.
    • Be careful to not break the circuit board as it is connected to the hinge.
  8. Kyocera Echo Camera Replacement: 步骤 8 中的图像 1,1
    • Push the camera gently out of its housing towards the side of the circuit board it is connected at to dislodge it.
  9. Kyocera Echo Camera Replacement: 步骤 9 中的图像 1,1
    • Grasp and pull up on the 32 pin connector attached to the circuit board to remove the camera.
结论
Alex Kinstedt
于11/05/18注册
483 声望
创作了4篇指南
团队
IUPUI, Team S2-G6, Baechle Fall 2018 IUPUI, Team S2-G6, Baechle Fall 2018 的会员
IUPUI-BAECHLE-F18S2G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 234
