跳转到主内容
Kyocera DuraForce Pro Headphone Jack Replacement
你所需要的
  1. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 2,3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 3,3
    • Flip the phone on its side so that the volume button is facing up.
    • Use the plastic opening tool to remove outer case of the phone.
    • Remove the 8 screws around the outer portion of the phone with a JIS #0 screwdriver.
  2. Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 2 中的图像 1,3 Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 2 中的图像 2,3 Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Remove the 2 screws with the same screwdriver bit.
    • Remove battery from the phone with plastic opening tool.
  3. Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 3 中的图像 1,3 Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 3 中的图像 2,3 Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Once the battery pops out, use tweezers to gently pull the ribbon out along with it.
    • Remove the 2 screws along the sides of the mounting bracket, then remove the bracket.
  4. Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 4 中的图像 1,3 Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 4 中的图像 2,3 Kyocera DuraForce Pro Headphone Jack Replacement: 步骤 4 中的图像 3,3
    • Remove final ribbon cable, lift the latch up, and then slide it down. The audio jack will then slide out.
结论
另外一个人完成了本指南。
Dylan Ulbricht
于10/08/18注册
735 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 1,338
