跳转到主内容
Kyocera DuraForce Pro Camera Replacement
你所需要的
  1. Kyocera DuraForce Pro Camera Replacement, Camera: 步骤 1 中的图像 1,3 Kyocera DuraForce Pro Camera Replacement, Camera: 步骤 1 中的图像 2,3 Kyocera DuraForce Pro Camera Replacement, Camera: 步骤 1 中的图像 3,3
    • Begin with the phone on its side.
    • Use the plastic opening tool to remove the cover. It is easier to begin near the volume button. The cover should pop off on its own.
  2. Kyocera DuraForce Pro Camera Replacement: 步骤 2 中的图像 1,3 Kyocera DuraForce Pro Camera Replacement: 步骤 2 中的图像 2,3 Kyocera DuraForce Pro Camera Replacement: 步骤 2 中的图像 3,3
    • Remove the 8 screws around the outer portion of the phone with the JIS #0 screwdriver bit.
    • Use the plastic opening tool to remove the backside of the phone.
    • Slide the plastic opening tool under the battery to pry it up and remove it.
  3. Kyocera DuraForce Pro Camera Replacement: 步骤 3 中的图像 1,3 Kyocera DuraForce Pro Camera Replacement: 步骤 3 中的图像 2,3 Kyocera DuraForce Pro Camera Replacement: 步骤 3 中的图像 3,3
    • Once the battery pops out, remove the orange tape that connects the battery to the phone.
    • Next, remove the 2 screws connecting the mounting bracket.
    • Remove mounting bracket.
  4. Kyocera DuraForce Pro Camera Replacement: 步骤 4 中的图像 1,2 Kyocera DuraForce Pro Camera Replacement: 步骤 4 中的图像 2,2
    • Pull the camera housing out of the phone.
结论
Dylan Ulbricht
于10/08/18注册
735 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,776
