跳转到主内容
Kyocera DuraForce PRO Battery Replacement
你所需要的
  1. Kyocera DuraForce PRO Battery Replacement, Remove Back Cover.: 步骤 1 中的图像 1,3 Kyocera DuraForce PRO Battery Replacement, Remove Back Cover.: 步骤 1 中的图像 2,3 Kyocera DuraForce PRO Battery Replacement, Remove Back Cover.: 步骤 1 中的图像 3,3
    • Make sure to power down phone before starting.
    • Insert the opening pick/tool into the slit between the case and the body of the phone. It can be easier to insert near buttons. Make your way around the case as you use the pick/tool to lift the cover from the body.
    • Once completely loose lift the cover off and set aside.
    • This is a good opportunity to blow out any dust that has accumulated.
  2. Kyocera DuraForce PRO Battery Replacement, Remove Waterproof Cover: 步骤 2 中的图像 1,3 Kyocera DuraForce PRO Battery Replacement, Remove Waterproof Cover: 步骤 2 中的图像 2,3 Kyocera DuraForce PRO Battery Replacement, Remove Waterproof Cover: 步骤 2 中的图像 3,3
    • Using your Phillips 000 remove the eight screws found in the waterproof cover.
    • Make sure to keep your screws in a small bowl or cup to keep them from rolling off the table.
    • Once the screws are removed, take your pick tool and make your way around the case as you use the pick/tool to lift the waterproof cover from the body.
    • Once loosen by the pick carefully remove the cover from the base and set aside.
    • Be careful of the buttons and port covers that will loosen and come off. If they come completely off set them aside and remember which location/direction they go.
    • Also be careful of the orange seal that is embedded in the waterproof cover. If it comes loose you can push back in place with tweezers.
  3. Kyocera DuraForce PRO Battery Replacement, Remove Battery: 步骤 3 中的图像 1,3 Kyocera DuraForce PRO Battery Replacement, Remove Battery: 步骤 3 中的图像 2,3 Kyocera DuraForce PRO Battery Replacement, Remove Battery: 步骤 3 中的图像 3,3
    • Highly recommend making sure you are grounded before removing the battery. You will be handling areas that could cause damage if you accidentally create a static discharge.
    • You will notice a disclaimer on the battery that states that if you remove the battery you void the warranty. Make sure your warranty has expired before performing this repair.
    • Starting near the lower area of the phone, carefully press the battery towards the top of the phone and then lift up.
    • Lift the battery up and over the top of the phone to expose the battery cable and port.
    • Using tweezers and opening tool, flip the lock on the port and carefully pull out the cable.
结论
19等其他人完成本指南。
Mike Rote
于02/01/18注册
632 声望
撰写一个指南
7条评论
As of June 2018 there is no new SCP-67LBPS , battery replacement available for the pro.. only used batteries from cannibalized phones.
for anyone interested here is a video of df pro battery removal
https://youtu.be/gz53p6mkAHA
freewillieklr - 回复
I am going to try method.
Angel Fulton - 回复
No new battery to buy for this phone? Maybe can buy from Kyocera?
danwat1234 - 回复
FidgetFidget OEM New Battery for Kyocera Duraforce PRO E6820 E6810 SCP-67LBPS 3240mAh 3.8V https://www.amazon.com/dp/B07H2BNLCZ/ref...
Andrew Messer -
Shopping sites in Japan are still selling SCP-67LBPS . Maybe they can’t send batteries to US. If you have a friend in Japan. You can ask him/her to get it.
https://www.denchi-mall.org/mobile-phone...
Nobuaki Yamashita - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 57
过去 30 天: 294
总计 26,273
