跳转到主内容
Kwikset 450248 Battery Replacement
你所需要的
  1. Kwikset 450248 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Kwikset 450248 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Ensure you are changing the batteries on this model of the Kwikset digital door lock.
    • Prepare your AA batteries and flat head screwdriver before changing the battery.
  2. Kwikset 450248 Battery Replacement: 步骤 2 中的图像 1,3 Kwikset 450248 Battery Replacement: 步骤 2 中的图像 2,3 Kwikset 450248 Battery Replacement: 步骤 2 中的图像 3,3
    • Use your flathead screwdriver to pry your Kwikset door lock cover open.
    • Push up on the cover.
    • Slide the cover up to display the battery storage area.
  3. Kwikset 450248 Battery Replacement: 步骤 3 中的图像 1,2 Kwikset 450248 Battery Replacement: 步骤 3 中的图像 2,2
    • Grab the top of the battery storage area.
    • Pull the battery storage area out of the device.
  4. Kwikset 450248 Battery Replacement: 步骤 4 中的图像 1,2 Kwikset 450248 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove all four batteries from the battery storage area.
    • Open the battery package and take four batteries out.
    • Place the new batteries into the battery storage area.
  5. Kwikset 450248 Battery Replacement: 步骤 5 中的图像 1,1
    • Put the battery storage device back into the Kwikset door lock.
    • Ensure the yellow label is facing you.
  6. Kwikset 450248 Battery Replacement: 步骤 6 中的图像 1,1
    • Slide the cover back onto the Kwikset digital door lock.
结论
To ensure that the Kwikset digital door lock is reassembled properly turn the lock, and listen for the door lock to state door locked or door unlocked.
Taylor S. Matthews
于09/28/21注册
133 声望
撰写一个指南
团队
UNT-Martin-F23S1G14 UNT-Martin-F23S1G14 的会员
Community
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 73
总计 276
