跳转到主内容
Kurio Xtreme Speaker Replacement
你所需要的
  1. Kurio Xtreme Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Speaker Replacement: 步骤 2 中的图像 1,2 Kurio Xtreme Speaker Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Speaker Replacement: 步骤 3 中的图像 1,3 Kurio Xtreme Speaker Replacement: 步骤 3 中的图像 2,3 Kurio Xtreme Speaker Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Speaker Replacement, Speaker: 步骤 4 中的图像 1,2 Kurio Xtreme Speaker Replacement, Speaker: 步骤 4 中的图像 2,2
    • Disconnect the 2 sets of black and red wires (4 wires total) from the motherboard by soldering the ends connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Speaker Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the speakers out of the plastic molds by lifting up the black and red wires.
结论
Mallory Myers
于09/22/15注册
1,190 声望
创作了7篇指南
团队
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 的会员
BU-WILLIAMS-F15S6G10
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 229
