跳转到主内容
Kurio Xtreme Battery Replacement
你所需要的
  1. Kurio Xtreme Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Battery Replacement: 步骤 2 中的图像 1,2 Kurio Xtreme Battery Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Battery Replacement: 步骤 3 中的图像 1,3 Kurio Xtreme Battery Replacement: 步骤 3 中的图像 2,3 Kurio Xtreme Battery Replacement: 步骤 3 中的图像 3,3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Battery Replacement, Battery: 步骤 4 中的图像 1,2 Kurio Xtreme Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Disconnect the black and red wires from the motherboard by soldering the ends that are connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Battery Replacement: 步骤 5 中的图像 1,2 Kurio Xtreme Battery Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device.
结论
2等其他人完成本指南。
Mallory Myers
于09/22/15注册
1,190 声望
创作了7篇指南
团队
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 的会员
BU-WILLIAMS-F15S6G10
3 名成员
创作了14篇指南
2条评论
j ai changé de batterie mais la batterie ne charge pas. est ce que c ets parce qu un des deux fils serait mal soudé?
j-p1955 - 回复
Does it have a certain battery or can a different battery fit?
Nikki Gilliard - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 3,948
