跳转到主内容
Kurio Touch 4S Power Button Replacement
你所需要的
  1. Kurio Touch 4S Power Button Replacement, Power Button: 步骤 1 中的图像 1,1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Power Button Replacement: 步骤 2 中的图像 1,3 Kurio Touch 4S Power Button Replacement: 步骤 2 中的图像 2,3 Kurio Touch 4S Power Button Replacement: 步骤 2 中的图像 3,3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Power Button Replacement: 步骤 3 中的图像 1,2 Kurio Touch 4S Power Button Replacement: 步骤 3 中的图像 2,2
    • To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Power Button Replacement: 步骤 4 中的图像 1,1
    • After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Power Button Replacement: 步骤 5 中的图像 1,1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  6. Kurio Touch 4S Power Button Replacement: 步骤 6 中的图像 1,1
    • Gently remove the plastic cover that is covering the camera.
  7. Kurio Touch 4S Power Button Replacement: 步骤 7 中的图像 1,1
    • Use Phillips # 1 screw to open the four 5mm Philips screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Power Button Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Power Button Replacement: 步骤 9 中的图像 1,1
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Power Button Replacement: 步骤 10 中的图像 1,2 Kurio Touch 4S Power Button Replacement: 步骤 10 中的图像 2,2
    • Detach all the wire that are connected to the motherboard.
    • Detach the camera module and other components that are attached to the motherboard.
  11. Kurio Touch 4S Power Button Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Power Button Replacement: 步骤 12 中的图像 1,1
    • Use tweezers to hold the power button and gently lift it up.
    • Replace the old power button with the new one.
结论
另外一个人完成了本指南。
Moin Khan
于01/21/15注册
234 声望
创作了2篇指南
团队
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 的会员
USFT-BROWN-W15S6G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 465
