跳转到主内容
Kurio Touch 4S Front & Rear Facing Cameras Replacement
你所需要的
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: 步骤 1 中的图像 1,1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 2 中的图像 1,3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 2 中的图像 2,3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 2 中的图像 3,3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 3 中的图像 1,3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 3 中的图像 2,3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 3 中的图像 3,3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 4 中的图像 1,1
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 5 中的图像 1,1
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 7 中的图像 1,2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 7 中的图像 2,2
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 8 中的图像 1,2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: 步骤 8 中的图像 2,2
    • Remove the copper wires by using the Tweezers to replace your new camera.
结论
另外一个人完成了本指南。
Khalid AlTamimi
于01/21/15注册
275 声望
创作了2篇指南
团队
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 的会员
USFT-BROWN-W15S6G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 250
