跳转到主内容
Kurio 10S Speakers Replacement
你所需要的
  1. Kurio 10S Speakers Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Speakers Replacement: 步骤 2 中的图像 1,2 Kurio 10S Speakers Replacement: 步骤 2 中的图像 2,2
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Speakers Replacement: 步骤 3 中的图像 1,1
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
    • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
  4. Kurio 10S Speakers Replacement: 步骤 4 中的图像 1,1
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Speakers Replacement, Speakers: 步骤 5 中的图像 1,1
    • Locate the two speakers on either side of the device
  6. Kurio 10S Speakers Replacement: 步骤 6 中的图像 1,2 Kurio 10S Speakers Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully disconnect the black and red wire from the motherboard using tweezers
    • Caution: motherboard parts are very fragile, so be careful when removing the wires
  7. Kurio 10S Speakers Replacement: 步骤 7 中的图像 1,1
    • Remove the speaker from its holder.
结论
另外一个人完成了本指南。
Hanna Desilets
于03/25/15注册
122 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-6, Shastany Spring 2015 UMass Dartmouth, Team 1-6, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G6
4 名成员
创作了8篇指南
一条评论
This tutorial was veryhelpful
Ralph Watson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 228
