跳转到主内容
Kurio 10S Motherboard Replacement
你所需要的
  1. Kurio 10S Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Motherboard Replacement: 步骤 2 中的图像 1,1
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Motherboard Replacement: 步骤 3 中的图像 1,1
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
  4. Kurio 10S Motherboard Replacement: 步骤 4 中的图像 1,1
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the electrical tape surrounding the battery.
  6. Kurio 10S Motherboard Replacement: 步骤 6 中的图像 1,2 Kurio 10S Motherboard Replacement: 步骤 6 中的图像 2,2
    • Locate the red and black wire connections where the battery is connected to the motherboard.
    • Now remove the red and black wires by soldering the ends of the wires off where they connect to the motherboard.
  7. Kurio 10S Motherboard Replacement: 步骤 7 中的图像 1,1
    • Locate and remove the copper tape connecting the motherboard to the back of the screen
  8. Kurio 10S Motherboard Replacement: 步骤 8 中的图像 1,3 Kurio 10S Motherboard Replacement: 步骤 8 中的图像 2,3 Kurio 10S Motherboard Replacement: 步骤 8 中的图像 3,3
    • Locate the ribbon cables connecting the motherboard to the screen and other peripherals.
    • Carefully lift the black part of the cable connector on the motherboard and pull the cable from the connector.
  9. Kurio 10S Motherboard Replacement: 步骤 9 中的图像 1,1
    • Locate and remove the four screws holding the motherboard on the device using the philips head screwdriver.
  10. Kurio 10S Motherboard Replacement: 步骤 10 中的图像 1,1
    • Locate and desolder the wires going to the speakers on each side of the device.
    • The motherboard can now be removed and replaced.
结论
2等其他人完成本指南。
Ryan Kelley
于04/07/15注册
155 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-6, Shastany Spring 2015 UMass Dartmouth, Team 1-6, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G6
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 985
