简介
Over time, the battery may wear out, or be damaged, and must be replaced in order for your device to function. Doing this may also help if your device runs out of battery very quickly or if you need to access other components in the tablet. This guide will walk you through the steps on how to replace the battery in your Kurio 10S.
你所需要的
Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
2等其他人完成本指南。
