跳转到主内容
Kurio 10S Battery Replacement
你所需要的
  1. Kurio 10S Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Battery Replacement: 步骤 2 中的图像 1,2 Kurio 10S Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Battery Replacement: 步骤 3 中的图像 1,1
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
    • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
  4. Kurio 10S Battery Replacement: 步骤 4 中的图像 1,1
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
  5. Kurio 10S Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Remove the electrical tape surrounding the battery.
    • Take care when working near the wires under the electrical tape and around the battery, as they may be fragile.
  6. Kurio 10S Battery Replacement: 步骤 6 中的图像 1,1
    • Once the electrical tape is removed there should be a metal bar across the battery.
    • Using a philip's head screwdriver, remove the screws on both ends and take off the metal bar.
  7. Kurio 10S Battery Replacement: 步骤 7 中的图像 1,2 Kurio 10S Battery Replacement: 步骤 7 中的图像 2,2
    • Locate the red and black wire connections where the battery is connected to the motherboard.
    • Now remove the red and black wires by soldering the ends of the wires off where they connect to the motherboard.
    • Caution: Soldering irons run hot. When removing solder from the board, the iron heats up the components, so be careful when using one.
结论
2等其他人完成本指南。
Timothy Kramer
于03/27/15注册
325 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-6, Shastany Spring 2015 UMass Dartmouth, Team 1-6, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S1G6
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 24
总计 1,299
