跳转到主内容
Krups F203 Coffee Grinder Plug/Cord Replacement
你所需要的
  1. Krups F203 Coffee Grinder Plug/Cord Replacement, Base Plate: 步骤 1 中的图像 1,1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Plug/Cord Replacement: 步骤 2 中的图像 1,3 Krups F203 Coffee Grinder Plug/Cord Replacement: 步骤 2 中的图像 2,3 Krups F203 Coffee Grinder Plug/Cord Replacement: 步骤 2 中的图像 3,3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Plug/Cord Replacement: 步骤 3 中的图像 1,2 Krups F203 Coffee Grinder Plug/Cord Replacement: 步骤 3 中的图像 2,2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: 步骤 4 中的图像 1,2 Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: 步骤 4 中的图像 2,2
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Plug/Cord Replacement, Remove the wire from two contact points: 步骤 5 中的图像 1,1
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
结论
另外一个人完成了本指南。
Ian Hancock
于10/22/14注册
414 声望
创作了3篇指南
团队
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 2,930
