跳转到主内容
Krups F203 Coffee Grinder Motor Replacement
你所需要的
  1. Krups F203 Coffee Grinder Motor Replacement, Base Plate: 步骤 1 中的图像 1,1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Motor Replacement: 步骤 2 中的图像 1,3 Krups F203 Coffee Grinder Motor Replacement: 步骤 2 中的图像 2,3 Krups F203 Coffee Grinder Motor Replacement: 步骤 2 中的图像 3,3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Motor Replacement: 步骤 3 中的图像 1,2 Krups F203 Coffee Grinder Motor Replacement: 步骤 3 中的图像 2,2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Motor Replacement, Detach Trigger Button from Base Plate: 步骤 4 中的图像 1,1
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Motor Replacement: 步骤 5 中的图像 1,2 Krups F203 Coffee Grinder Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the white trigger.
  6. Krups F203 Coffee Grinder Motor Replacement: 步骤 6 中的图像 1,1
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
  7. Krups F203 Coffee Grinder Motor Replacement, Motor: 步骤 7 中的图像 1,1
    • Desolder remaining contact point from the plug cord
  8. Krups F203 Coffee Grinder Motor Replacement: 步骤 8 中的图像 1,2 Krups F203 Coffee Grinder Motor Replacement: 步骤 8 中的图像 2,2
    • Using a Phillips screwdriver, remove the two screws holding the motor in place.
  9. Krups F203 Coffee Grinder Motor Replacement: 步骤 9 中的图像 1,1
    • Remove the motor from the shell.
结论
6等其他人完成本指南。
Ian Hancock
于10/22/14注册
414 声望
创作了3篇指南
团队
Baylor, Team 4-2, Williams Fall 2014 Baylor, Team 4-2, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G2
3 名成员
创作了8篇指南
7条评论
thank you so much
Nikolai Podrez - 回复
Doesn’t seem to apply to the Type 203. It looks different.
rpoland - 回复
The first photo of the bottom plate is too dark to show details. I have type 203 B Made in France and the clips didn’t budge without first breaking/stretching the thin outer walls of the base plate. No need to remove the wires. With mine, you have to turn the bottom shaft of the motor with a screwdriver (counter clockwise as usual) while holding the blade stationary which unscrews the blade from the motor enabling you to remove the motor after the two phillips screws are removed.
seeley6 - 回复
Hi Ian!
Nice explanation!
Can you provide a close up of the spudger that you used for opening the bottom plate?
I want to use the correct one, so I don ´t break that aged plastic cover.
Bengt
Yngve Lien - 回复
Where does one get the replacement motor?
Andrea Garrity - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 30
过去 30 天: 122
总计 27,205
