跳转到主内容
Krups CafeExpress FMA110 Disassembly
你所需要的
  1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: 步骤 1 中的图像 1,2 Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: 步骤 1 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
    • Remove the metal plate.
  2. Krups CafeExpress FMA110 Disassembly: 步骤 2 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
  3. Krups CafeExpress FMA110 Disassembly: 步骤 3 中的图像 1,2 Krups CafeExpress FMA110 Disassembly: 步骤 3 中的图像 2,2
    • Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
  4. Krups CafeExpress FMA110 Disassembly: 步骤 4 中的图像 1,1
    • Carefully pull the silicon tubing off of the metal tube.
  5. Krups CafeExpress FMA110 Disassembly: 步骤 5 中的图像 1,2 Krups CafeExpress FMA110 Disassembly: 步骤 5 中的图像 2,2
    • Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
  6. Krups CafeExpress FMA110 Disassembly: 步骤 6 中的图像 1,1
    • Carefully remove the silicon tubing from the upper reservoir.
  7. Krups CafeExpress FMA110 Disassembly: 步骤 7 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
  8. Krups CafeExpress FMA110 Disassembly: 步骤 8 中的图像 1,1
    • Separate the base of the device from the upper reservoir.
  9. Krups CafeExpress FMA110 Disassembly: 步骤 9 中的图像 1,1
    • Push the switch out from the inside, releasing it from the plastic base.
  10. Krups CafeExpress FMA110 Disassembly: 步骤 10 中的图像 1,1
    • Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
  11. Krups CafeExpress FMA110 Disassembly: 步骤 11 中的图像 1,1
    • Slide the rest of the switch back through the hole in the base.
  12. Krups CafeExpress FMA110 Disassembly: 步骤 12 中的图像 1,2 Krups CafeExpress FMA110 Disassembly: 步骤 12 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
  13. Krups CafeExpress FMA110 Disassembly: 步骤 13 中的图像 1,2 Krups CafeExpress FMA110 Disassembly: 步骤 13 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
  14. Krups CafeExpress FMA110 Disassembly: 步骤 14 中的图像 1,1
    • Remove the horizontal bracket to separate the heating element and wires from the hot plate.
  15. Krups CafeExpress FMA110 Disassembly: 步骤 15 中的图像 1,1
    • Disconnect the wire connectors from the thermal switch.
  16. Krups CafeExpress FMA110 Disassembly: 步骤 16 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
  17. Krups CafeExpress FMA110 Disassembly: 步骤 17 中的图像 1,2 Krups CafeExpress FMA110 Disassembly: 步骤 17 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
    • Separate the hot plate from its frame.
  18. Krups CafeExpress FMA110 Disassembly: 步骤 18 中的图像 1,2 Krups CafeExpress FMA110 Disassembly: 步骤 18 中的图像 2,2
    • Once the heating element reaches a certain temperature, the thermal switch shuts it off to prevent it from overheating.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 185
