你所需要的
Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Remove the three 60mm Phillips size 0 screws holding the top cover on.
Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
Use a Phillip size 2 screw driver to remove the four 15mm screws holding the pump to the machine's base.
Lift the water heater up and remove it from the base.
2条评论
Where do you get the new heater to replace the broken one that does not work?
The broken heating element is removed. Where do you get a new one to replace the broken one?
