跳转到主内容
Krups 963 Power Switch Replacement
你所需要的
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: 步骤 1 中的图像 1,1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: 步骤 3 中的图像 1,1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: 步骤 4 中的图像 1,1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: 步骤 5 中的图像 1,1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
结论
Wyatt Hall
于10/13/14注册
842 声望
创作了7篇指南
团队
Cal Poly, Team 6-25, Maness Fall 2014 Cal Poly, Team 6-25, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G25
4 名成员
创作了7篇指南
一条评论
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 3,080
