跳转到主内容
加入维修社区 - 创建账户
本篇指南是分解流程而非维修指南。 如果您要维修您的Korg Volca Mix,应参考我们的维修指南
  1. Korg Volca Mix Teardown, Remove the PCBs from the case: 步骤 1 中的图像 1,3 Korg Volca Mix Teardown, Remove the PCBs from the case: 步骤 1 中的图像 2,3 Korg Volca Mix Teardown, Remove the PCBs from the case: 步骤 1 中的图像 3,3
    • Remove eight screws.
    • Remove the bottom plastic case. You will see the PCB.
    • Remove four further screws and unlatch the two loudspeaker-jacks.
    • Remove the three Hi/Lo-Cut knobs and the three fadercaps. You can now remove the PCB from the case.
  2. Korg Volca Mix Teardown, The Top Side: 步骤 2 中的图像 1,1
    • Texas Instruments - TPS54231 2A, 28V-Input Step-Down DC/DC-Converter.
    • Texas Instruments - CD4013B D-Flipflop. I am not sure if this is correct. The Marking is CM013B/77K G4/A32G
    • National Semiconductor - LM386 Low Voltage Audio Power Amplifier
    • ST Microelectonics - STM32F030F4 Microcontroller.
    • JRC - NJM4556A Dual High-Current Operational Amplifier
    • ST Microelectronics - TL084CDT JFET Quad Operational Amplifier
  3. Korg Volca Mix Teardown, The Bottom Side: 步骤 3 中的图像 1,1
    • Texas Instruments - CD4013 D-Flipflop
    • ST Microelectronics - LT084CDT JFET Quad Operational Amplifier
Christian
于03/09/14注册
1,655 声望
创作了8篇指南
1指南评论
thank's for this guide
Skander BEN M'RAD - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 37
总计 1,402
