跳转到主内容
Konica Minolta DiMAGE Z3 LCD Screen Replacement
你所需要的
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: 步骤 1 中的图像 1,2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: 步骤 1 中的图像 2,2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: 步骤 2 中的图像 1,1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: 步骤 3 中的图像 1,2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: 步骤 3 中的图像 2,2
    • Use a screwdriver to remove the four viewfinder cover screws.
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: 步骤 4 中的图像 1,1
    • Remove the 2 small screws under the viewfinder.
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: 步骤 5 中的图像 1,1
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: 步骤 6 中的图像 1,1
    • Remove 6 screws on the bottom panel.
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: 步骤 7 中的图像 1,1
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove 1 screw inside the battery chamber.
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Remove the 3 screws that attach the LCD screen to the circuit board.
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
结论
Hieu Ngo
于03/22/17注册
431 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 22
总计 661
