简介
This only dissassembles the front part of the viewfinder (the one sticking out of the front cover). This was removed for cleaning. For the rest of the viewfinder a soldergun is needed. I did not need to go that deep.
你所需要的
The machinery is now open and can be dissasembled further or the front cover might be cleaned freely without worry that cleaning liquid would seep into the camera.
Make sure to remember what the "roll and lock" switch was on before dissassembly or to not touch it at all.
You might need to push the brass lever that holds the wires in place (right under the small board on the leftside) up to fit the front cover back on.
If its stuck in place in the wrong position, loosen the screw attached to it a little bit to pry it back in it's original position.
2 flathead screws hold the viewfinder and lightmeter in place.
Remove them and then slide the viewfinder out from underneath the upper red wire.
You can now carefully clean both sides of the upper window with a piece of microfibre cloth.
Reassembling can be done by placing the viewfinder back in place and screwing the screws back in.
Start with the bottom, more easily accessable screw.
Then do the top, making sure the red wire is between the screw and the higher part of the viewfinder. It can fit just barely.
To reassemble your device, follow these instructions in reverse order. Make sure the red wire is above the lens and on the right side of the top screw.
