跳转到主内容
Kolcraft Cloud Plus "Free-Stand" Button Replacement
你所需要的
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: 步骤 1 中的图像 1,2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: 步骤 1 中的图像 2,2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: 步骤 3 中的图像 1,1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: 步骤 4 中的图像 1,1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
结论
团队
Cal Poly, Team 11-1, Forte Fall 2015 Cal Poly, Team 11-1, Forte Fall 2015 的会员
CPSU-FORTE-F15S11G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 33
总计 1,381
