简介
First, Front Cover Teardown guide must be used to get inside the camera in order to remove the lens.
配件
无需配件。
  1. Have the camera facing up and the flash closest to you.
    • Have the camera facing up and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Flip camera to other side-with flash farthest from you.
    • Flip camera to other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Turn the camera so the bottom is facing up with the front facing away.
    • Turn the camera so the bottom is facing up with the front facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted up evenly and removed.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. Remove the two 6.2mm Phillips screws on either side of the lens on the metal plate.
    • Remove the two 6.2mm Phillips screws on either side of the lens on the metal plate.
  6. Pull aside the top plastic piece resting on the metal lens plate in order to access the other screws.
    • Pull aside the top plastic piece resting on the metal lens plate in order to access the other screws.
  7. To remove other screws, metal panel must be lifted up slightly to access.
    • To remove other screws, metal panel must be lifted up slightly to access.
    • Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
  8. Look at the black plate on the right side of the lens that the metal plate is resting on.
    • Look at the black plate on the right side of the lens that the metal plate is resting on.
    • Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
    • At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
结论
Michelle
于2011年04月04日注册
86 信誉积分
创作了5篇指南
团队
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G28
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 1,362
