跳转到主内容
Kodak S100 EF Front Cover Replacement
你所需要的
  1. Kodak S100 EF Front Cover Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Front Cover Replacement: 步骤 2 中的图像 1,1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Front Cover Replacement: 步骤 3 中的图像 1,1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
结论
Michelle
于04/04/11注册
107 声望
创作了5篇指南
团队
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G28
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,993
