跳转到主内容
简介
To start, the Front Cover Teardown guide must be used. Later, soldering guides will be used.
  1. Have the camera facing up and the flash closest to you.
    • Have the camera facing up and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Flip camera to other side-with flash farthest from you.
    • Flip camera to other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  4. Turn the camera so the bottom is facing up with the front facing away.
    • Turn the camera so the bottom is facing up with the front facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted up evenly and removed.
  5. Once the front cover is off, desolder the connections at both ends of the flash.
    • Once the front cover is off, desolder the connections at both ends of the flash.
    • If unfamiliar with soldering, refer to the guide 如何焊接和脱焊
结论
Nick
于2011年04月26日注册
1 信誉积分
撰写一个指南
团队
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G28
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 9
总计 1,633
