跳转到主内容
Kodak S100 EF Back Cover Replacement
你所需要的
  1. Kodak S100 EF Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Kodak S100 EF Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Back Cover Replacement: 步骤 2 中的图像 1,1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Back Cover Replacement: 步骤 3 中的图像 1,1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
结论
Michelle
于04/04/11注册
107 声望
创作了5篇指南
团队
Cal Poly, Team 25-28, Garner Spring 2011 Cal Poly, Team 25-28, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G28
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 11
总计 1,550
