你所需要的
这个步骤还没有翻译 帮忙翻译一下
Use fingernails or small flathead screw driver to push black tabs on view finder cable connector away from board connector.
Slide screwdriver beneath length of flex and gently lift upwards to remove flex from connector.
Lift flap on lens flex and gently slide flex out.
Use finger nails to gently prise small white connector from LCD (bottom right of board) free.
这个步骤还没有翻译 帮忙翻译一下
Turn lens over so that rear of lens is facing up.
Lift flex on right of rear lens barrel to reveal screw, then remove 3 screws on rear of lens.
Remove 1 screw from left side of lens barrel (holding focus flex) optional step.
Slide flex through openings on rear lens housing to remove housing.
2条评论
jackmorin, I'm just curious; why did you feel it was necessary, to make that your comment of choice, knowing exactly what pollytintop meant; rather than, thank you for the time you put into posting this very helpful information. I would like to say, thank you pollytintop, this was very helpful & I appreciate this detailed information.
I would like to thank the author for putting this info together. I was able to find a video screen for the back of this cam2017era very reasonably on Ebay, and with the help of these instructions, replace the broken screen that had plagued this camera for years. It was with a gre/24/at sense of satisfaction that I can now use the camera with its full features. Thanks again!
Bill West - 4/24/2017
