跳转到主内容
Kodak Easyshare Z981 LCD Screen Replacement
你所需要的
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 2,2
    • Open the battery cover and remove batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 LCD Screen Replacement: 步骤 2 中的图像 1,2 Kodak Easyshare Z981 LCD Screen Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #00 Screwdriver
    $5.49
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
  4. Kodak Easyshare Z981 LCD Screen Replacement: 步骤 4 中的图像 1,2 Kodak Easyshare Z981 LCD Screen Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    $5.49
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  5. Kodak Easyshare Z981 LCD Screen Replacement: 步骤 5 中的图像 1,2 Kodak Easyshare Z981 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  6. Kodak Easyshare Z981 LCD Screen Replacement: 步骤 6 中的图像 1,2 Kodak Easyshare Z981 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
  7. Kodak Easyshare Z981 LCD Screen Replacement: 步骤 7 中的图像 1,3 Kodak Easyshare Z981 LCD Screen Replacement: 步骤 7 中的图像 2,3 Kodak Easyshare Z981 LCD Screen Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Gently lift up the metal brace and use a pair if tweezers to disconnect the ribbon cable connecter
    • Use Tweezers to disconnect the ribbon cable connector.
    • Once disconnected remove the screen brace from the circuit board
    • Use extreme caution when removing the LCD brace pulling the brace may tear the cable
结论
另外一个人完成了本指南。
Daniel Ramirez
于03/03/15注册
152 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 821
