跳转到主内容
Kodak Easyshare V1003 Lens Replacement
你所需要的
  1. Kodak Easyshare V1003 Lens  Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003 Lens  Replacement: 步骤 2 中的图像 1,1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003 Lens  Replacement: 步骤 3 中的图像 1,1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003 Lens  Replacement: 步骤 4 中的图像 1,1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003 Lens  Replacement: 步骤 5 中的图像 1,2 Kodak Easyshare V1003 Lens  Replacement: 步骤 5 中的图像 2,2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003 Lens  Replacement, Lens: 步骤 6 中的图像 1,2 Kodak Easyshare V1003 Lens  Replacement, Lens: 步骤 6 中的图像 2,2
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003 Lens  Replacement: 步骤 7 中的图像 1,1
    • Pull the outer case off using the plastic opening tool.
  8. Kodak Easyshare V1003 Lens  Replacement: 步骤 8 中的图像 1,2 Kodak Easyshare V1003 Lens  Replacement: 步骤 8 中的图像 2,2
    • Remove the LCD display by unplugging the connector
    • Take apart the LCD display from the back case
  9. Kodak Easyshare V1003 Lens  Replacement: 步骤 9 中的图像 1,2 Kodak Easyshare V1003 Lens  Replacement: 步骤 9 中的图像 2,2
    • Peel off the yellow film.
    • Peel off the black tape holding the wires.
  10. Kodak Easyshare V1003 Lens  Replacement: 步骤 10 中的图像 1,1
    • Unplug the connector by lifting the little lock holding it in place.
  11. Kodak Easyshare V1003 Lens  Replacement: 步骤 11 中的图像 1,2 Kodak Easyshare V1003 Lens  Replacement: 步骤 11 中的图像 2,2
    • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
  12. Kodak Easyshare V1003 Lens  Replacement: 步骤 12 中的图像 1,3 Kodak Easyshare V1003 Lens  Replacement: 步骤 12 中的图像 2,3 Kodak Easyshare V1003 Lens  Replacement: 步骤 12 中的图像 3,3
    • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
    • Gently pull out the lens using you finger tips or pincers.
结论
Sarah Berry
于03/21/17注册
301 声望
创作了3篇指南
团队
UMass Dartmouth, Team S9-G4, Martin Spring 2017 UMass Dartmouth, Team S9-G4, Martin Spring 2017 的会员
UMASSD-MARTIN-S17S9G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 307
