跳转到主内容
Kodak Easyshare V1003 LCD Display Replacement
你所需要的
  1. Kodak Easyshare V1003  LCD Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003  LCD Display Replacement: 步骤 2 中的图像 1,1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003  LCD Display Replacement: 步骤 3 中的图像 1,1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003  LCD Display Replacement: 步骤 4 中的图像 1,1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003  LCD Display Replacement: 步骤 5 中的图像 1,2 Kodak Easyshare V1003  LCD Display Replacement: 步骤 5 中的图像 2,2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003  LCD Display Replacement, Buttons: 步骤 6 中的图像 1,3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: 步骤 6 中的图像 2,3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: 步骤 6 中的图像 3,3
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003  LCD Display Replacement: 步骤 7 中的图像 1,3 Kodak Easyshare V1003  LCD Display Replacement: 步骤 7 中的图像 2,3 Kodak Easyshare V1003  LCD Display Replacement: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to pry off the back casing.
  8. Kodak Easyshare V1003  LCD Display Replacement: 步骤 8 中的图像 1,3 Kodak Easyshare V1003  LCD Display Replacement: 步骤 8 中的图像 2,3 Kodak Easyshare V1003  LCD Display Replacement: 步骤 8 中的图像 3,3
    • Completely remove the back casing from the device.
    • Using a plastic tool to remove the bottom.
  9. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: 步骤 9 中的图像 1,1
    • Remove the LCD display by unplugging the connector.
  10. Kodak Easyshare V1003  LCD Display Replacement: 步骤 10 中的图像 1,1
    • Take apart the LCD display from the back case.
结论
2等其他人完成本指南。
Vanessa Soares
于03/15/17注册
246 声望
创作了2篇指南
团队
UMass Dartmouth, Team S9-G4, Martin Spring 2017 UMass Dartmouth, Team S9-G4, Martin Spring 2017 的会员
UMASSD-MARTIN-S17S9G4
4 名成员
创作了10篇指南
1指南评论
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 20
总计 1,202
