跳转到主内容
Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution
你所需要的
  1. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Identify the problem: 步骤 1 中的图像 1,1
    • Identify that your printer is jammed. This is usually indicated by the paper light blinking quickly.
  2. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Removing the paper tray: 步骤 2 中的图像 1,1
    • Gently pull the paper tray out of the printing dock to remove it.
    • When the paper tray is empty, the paper light should glow a steady amber.
  3. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Disconnecting the power adapter: 步骤 3 中的图像 1,2 Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Disconnecting the power adapter: 步骤 3 中的图像 2,2
    • Disconnect the power adapter from the printer for 10 seconds, and then reconnect the cord.
    • On some models, you may have to press the power button in addition to plugging in the power adapter.
    • Wait for the printer to initialize in order for the jammed paper to exit from the back side.
    • Notice: Carefully remove the paper if it does not automatically eject.
  4. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Removing the paper supply: 步骤 4 中的图像 1,1
    • With the paper tray in hand, open the front lid in order to gain access to the paper supply.
    • Take hold of the paper bundle, and carefully “fan” it to keep the sheets from sticking together.
  5. Kodak Easyshare Printer Dock (Series 3) Paper Jam Solution, Reload and reinstall the paper tray: 步骤 5 中的图像 1,1
    • Reload the paper tray by sliding the paper bundle back into the intended slot, and then close the lid.
    • Next, slide the paper tray in the printer tray slot until the tray locks into place.
    • To ensure the paper tray fits squarely on the printer dock, make sure to keep the paper tray cover all the way open while installing.
    • Press the power or print button to clear the paper error and resume printing.
结论
Henry Ta
于10/13/16注册
101 声望
撰写一个指南
团队
University of Maine, Team 1-6, Diaz Fall 2016 University of Maine, Team 1-6, Diaz Fall 2016 的会员
UMAINE-DIAZ-F16S1G6
2 名成员
创作了1篇指南
一条评论
My doc is only print half of pic what can ido
Amy Winfree - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 26
过去 30 天: 90
总计 2,693
