跳转到主内容
Kodak Easyshare C813 Shutter Button Replacement
你所需要的
  1. Kodak Easyshare C813 Shutter Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Shutter Button Replacement: 步骤 2 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 2 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 2 中的图像 3,3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Shutter Button Replacement, Back Cover: 步骤 3 中的图像 1,1
    • Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Kodak Easyshare C813 Shutter Button Replacement: 步骤 4 中的图像 1,1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Shutter Button Replacement: 步骤 5 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 5 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 5 中的图像 3,3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  6. Kodak Easyshare C813 Shutter Button Replacement: 步骤 7 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 7 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 7 中的图像 3,3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  7. Kodak Easyshare C813 Shutter Button Replacement: 步骤 8 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 8 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 8 中的图像 3,3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  8. Kodak Easyshare C813 Shutter Button Replacement, Front Cover: 步骤 9 中的图像 1,2 Kodak Easyshare C813 Shutter Button Replacement, Front Cover: 步骤 9 中的图像 2,2
    • Open the battery door.
  9. Kodak Easyshare C813 Shutter Button Replacement: 步骤 10 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 10 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 10 中的图像 3,3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  10. Kodak Easyshare C813 Shutter Button Replacement: 步骤 11 中的图像 1,1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  11. Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: 步骤 12 中的图像 1,2 Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: 步骤 12 中的图像 2,2
    • The shutter button is held on to the front cover by three screws
    • Hold the shutter button in place
    • Use a Philips 00 screwdriver to remove the screws.
    • Careful that the power and flash button do not fall off
  12. Kodak Easyshare C813 Shutter Button Replacement: 步骤 13 中的图像 1,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 13 中的图像 2,3 Kodak Easyshare C813 Shutter Button Replacement: 步骤 13 中的图像 3,3
    • Keep the shutter button in place while removing the circular metal plate
    • Remove the shutter button by allowing it to fall into your hand
    • Hold down the shutter button portion of the selector dial
    • Press down the red tabs and slowly relieve pressure on the shutter button
    • Press down on the center red stick
    • Careful not to lose the spring
    • Tool shown is Found here
  13. Kodak Easyshare C813 Shutter Button Replacement: 步骤 15 中的图像 1,1
    • If cleaning, remove dirt from button
    • When putting back together, the button should be be oriented so that the green automatic mode points towards the power button.
结论
Susan Marano
于04/15/10注册
336 声望
创作了7篇指南
团队
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G22
4 名成员
创作了20篇指南
一条评论
does anybody know how the pins works on the surface mounted shutter switch button on the PCB? this would be very helpful thanks!
random - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 21
总计 7,526
