简介
This guide demonstrates how to replace the lens.
你所需要的
Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
在这个步骤中使用的工具:Anti-Static Wrist Strap$7.95
Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
在这个步骤中使用的工具:Phillips #00 Screwdriver$5.49
Remove all 7 screws:
Hold the camera firmly with one hand so that you can still see a screw.
Place the Philips 00(Found here)screwdriver into the screw.
Turn the screwdriver to the left until it is free.
Repeat for the remaining screws.
Open the battery door.
Press thumb firmly on battery door and slide it in the direction of the arrow.
Lift thumb allowing the door to swing open.
The battery door on my easyshare c813 is broken. How can i get a replacement door?
Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
Remove the 3 screws securing the lens to the camera.
Gently remove the lens from the remaining casing.
2等其他人完成本指南。
一条评论
Great, please I need help on my Kodak easyshare z1085 IS, other things is working, but always black can't see anything through the screen
