跳转到主内容
Kodak Easyshare C183 Lens Assembly Replacement
你所需要的
  1. Kodak Easyshare C183 Lens Assembly Replacement, Lens: 步骤 1 中的图像 1,3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: 步骤 1 中的图像 2,3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: 步骤 1 中的图像 3,3
    • Remove the batteries, memory card and wrist strap, if so equipped.
    • Remove the three Phillips screws on the bottom.
    • Remove the two Phillips screws on the right hand side.
  2. Kodak Easyshare C183 Lens Assembly Replacement: 步骤 2 中的图像 1,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 2 中的图像 2,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws on the left hand side.
    • Nicely enough, all the screws are the same size. No need to keep them separated.
    • Start splitting the case from the battery holder. You can use an opening tool or just your fingernails.
  3. Kodak Easyshare C183 Lens Assembly Replacement: 步骤 3 中的图像 1,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 3 中的图像 2,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 3 中的图像 3,3
    • The camera's front half will come off first.
    • Remove the one screw on the top left of the camera. It this holds the back case on to the midframe.
    • Remove the back case.
  4. Kodak Easyshare C183 Lens Assembly Replacement: 步骤 4 中的图像 1,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 4 中的图像 2,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 4 中的图像 3,3
    • Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
    • Remove the one screw on the top corner of the holder.
    • Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
    • Remove the solder that connects the LCD holder to the top logic board.
  5. Kodak Easyshare C183 Lens Assembly Replacement: 步骤 5 中的图像 1,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 5 中的图像 2,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 5 中的图像 3,3
    • The LCD holding board and the switches are removed as one unit.
    • Open the clip on the LCD ribbon cable connector. Use your fingernails to gently pull it toward the top of the camera.
    • Remove the LCD.
  6. Kodak Easyshare C183 Lens Assembly Replacement: 步骤 6 中的图像 1,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 6 中的图像 2,3 Kodak Easyshare C183 Lens Assembly Replacement: 步骤 6 中的图像 3,3
    • Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
    • Remove the two screws that hold the lens in place.
    • With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
  7. Kodak Easyshare C183 Lens Assembly Replacement: 步骤 7 中的图像 1,1
    • This is what your final result should look like. the lens is now free from the midframe and a new lens can be easily installed.
结论
另外一个人完成了本指南。
oldturkey03
于09/29/10注册
782,216 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
33 名成员
创作了537篇指南
2条评论
ممنون از اطلاعات تان
hamid kaker - 回复
خواهش میکنم. امیدوارم کمک کرده باشد.
oldturkey03 -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 1,842
