跳转到主内容
Kodak EasyShare Z740 Lens Cover Replacement
  1. Kodak EasyShare Z740 Lens Cover Replacement, Lens Cover: 步骤 1 中的图像 1,2 Kodak EasyShare Z740 Lens Cover Replacement, Lens Cover: 步骤 1 中的图像 2,2
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
  2. Kodak EasyShare Z740 Lens Cover Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 2 中的图像 3,3
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
  3. Kodak EasyShare Z740 Lens Cover Replacement: 步骤 3 中的图像 1,2 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 3 中的图像 2,2
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
  4. Kodak EasyShare Z740 Lens Cover Replacement: 步骤 4 中的图像 1,3 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 4 中的图像 2,3 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 4 中的图像 3,3
    • Separate the two pieces of the loop and pull the lens cover up in between them.
  5. Kodak EasyShare Z740 Lens Cover Replacement: 步骤 5 中的图像 1,3 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 5 中的图像 2,3 Kodak EasyShare Z740 Lens Cover Replacement: 步骤 5 中的图像 3,3
    • Pull the lens cover and the sting will come out of the metal slab.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 690
