跳转到主内容
Kodak EasyShare Z1015 IS SD Memory Card Replacement
你所需要的
  1. Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: 步骤 1 中的图像 1,2 Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: 步骤 1 中的图像 2,2
    • In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
    • Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
  2. Kodak EasyShare Z1015 IS SD Memory Card Replacement: 步骤 2 中的图像 1,2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: 步骤 2 中的图像 2,2
    • After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
  3. Kodak EasyShare Z1015 IS SD Memory Card Replacement: 步骤 3 中的图像 1,2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: 步骤 3 中的图像 2,2
    • After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
结论
另外一个人完成了本指南。
katie newman
于10/28/10注册
30 声望
创作了3篇指南
团队
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G16
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 2,811
