跳转到主内容
Kodak EasyShare Z1015 IS Lens Cover Replacement
  1. Kodak EasyShare Z1015 IS Lens Cover Replacement, Lens Cover: 步骤 1 中的图像 1,1
    • Begin by placing the string that is attached to the lens cover underneath the metal bar located on the right side of the camera.
  2. Kodak EasyShare Z1015 IS Lens Cover Replacement: 步骤 2 中的图像 1,2 Kodak EasyShare Z1015 IS Lens Cover Replacement: 步骤 2 中的图像 2,2
    • After successfully placing the string through the metal slab, pull the string all the way to the right which will leave enough room to tie the lens cover to the camera.
  3. Kodak EasyShare Z1015 IS Lens Cover Replacement: 步骤 3 中的图像 1,2 Kodak EasyShare Z1015 IS Lens Cover Replacement: 步骤 3 中的图像 2,2
    • Next, create a loop with the string and send the lens cover through the loop. This will create a knot to ensure that the lens cover will always remain on the camera.
    • Lastly, pull the lens cover to the right which will tighten the knot. To conclude, simply attach the lens cover to the lens.
结论
Jack
于10/10/10注册
190 声望
创作了3篇指南
团队
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G16
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 3,796
