跳转到主内容
Kodak EasyShare Z1015 IS Internal frame Replacement
你所需要的
  1. Kodak EasyShare Z1015 IS Internal frame Replacement, Battery: 步骤 1 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 2 中的图像 1,1
    • Next, press down on the red lever which holds the battery in place.
  3. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 3 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 3 中的图像 2,2
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
  4. Kodak EasyShare Z1015 IS Internal frame Replacement, Back Cover: 步骤 4 中的图像 1,3 Kodak EasyShare Z1015 IS Internal frame Replacement, Back Cover: 步骤 4 中的图像 2,3 Kodak EasyShare Z1015 IS Internal frame Replacement, Back Cover: 步骤 4 中的图像 3,3
    • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
    • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
    • Begin by removing the first screw located on the back of the camera.
  5. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 5 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 5 中的图像 2,2
    • Next, remove the two screws located on the right side of the camera.
  6. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 6 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 6 中的图像 2,2
    • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  7. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 7 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 7 中的图像 2,2
    • Lastly, remove the two screws located on the left side of the camera.
    Trés bon tuto !!! bravo
    Aprés, comment réparer les contacts des touches de selection ,
    André kremer - 回复
  8. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 8 中的图像 1,3 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 8 中的图像 2,3 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 8 中的图像 3,3
    • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
    • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  9. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 9 中的图像 1,3 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 9 中的图像 2,3 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 9 中的图像 3,3
    • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
    • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
  10. Kodak EasyShare Z1015 IS Internal frame Replacement, LCD: 步骤 10 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement, LCD: 步骤 10 中的图像 2,2
    • Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
  11. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 11 中的图像 1,1
    • Gently remove the LCD screen from it's interior casing by lifting and pulling from the right side.
    • Be incredibly cautious not to pull to hard on the screen, doing so may rip the ribbon that connects the screen to the logic board and permanently damage your camera.
  12. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 12 中的图像 1,3 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 12 中的图像 2,3 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 12 中的图像 3,3
    • To completely remove the LCD screen from the interior of the camera, you must unhook the ribbon from the logic board.
    • To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen.
  13. Kodak EasyShare Z1015 IS Internal frame Replacement, Internal frame: 步骤 13 中的图像 1,3 Kodak EasyShare Z1015 IS Internal frame Replacement, Internal frame: 步骤 13 中的图像 2,3 Kodak EasyShare Z1015 IS Internal frame Replacement, Internal frame: 步骤 13 中的图像 3,3
    • Begin by unscrewing all four screws found in each corner of the frame
  14. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 14 中的图像 1,1
    • Next, use Plastic Opening Tools to loosen the frame from the camera. Do this by placing the tool in between the frame and the camera and applying leverage.
    • Avoid placing the opening tool in between the frame and camera on the bottom side of the device. There is ribbon there that could easily be damaged if not carefully avoided.
  15. Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 15 中的图像 1,2 Kodak EasyShare Z1015 IS Internal frame Replacement: 步骤 15 中的图像 2,2
    • After loosening the frame with the opening tools, gently remove the frame from the interior of the camera.
结论
2等其他人完成本指南。
Jack
于10/10/10注册
190 声望
创作了3篇指南
团队
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G16
4 名成员
创作了11篇指南
一条评论
I have a Kodac DX7630 and a Kodac DX4530 both with the same problem..the monitor is black.The rest functions perfectly.Cam they be repaired and will there still be parts available?
Many thanks
Denzil
Denzil Terblanche - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,747
