跳转到主内容
Kodak EasyShare Z1015 IS Back Cover Replacement
你所需要的
  1. Kodak EasyShare Z1015 IS Back Cover Replacement, Battery: 步骤 1 中的图像 1,2 Kodak EasyShare Z1015 IS Back Cover Replacement, Battery: 步骤 1 中的图像 2,2
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 2 中的图像 1,1
    • Next, press down on the red lever which holds the battery in place.
  3. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 3 中的图像 1,2 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 3 中的图像 2,2
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
  4. Kodak EasyShare Z1015 IS Back Cover Replacement, Back Cover: 步骤 4 中的图像 1,3 Kodak EasyShare Z1015 IS Back Cover Replacement, Back Cover: 步骤 4 中的图像 2,3 Kodak EasyShare Z1015 IS Back Cover Replacement, Back Cover: 步骤 4 中的图像 3,3
    • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
    • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
    • Begin by removing the first screw located on the back of the camera.
  5. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 5 中的图像 1,2 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 5 中的图像 2,2
    • Next, remove the two screws located on the right side of the camera.
  6. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 6 中的图像 1,2 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 6 中的图像 2,2
    • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  7. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 7 中的图像 1,2 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 7 中的图像 2,2
    • Lastly, remove the two screws located on the left side of the camera.
  8. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 8 中的图像 1,3 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 8 中的图像 2,3 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 8 中的图像 3,3
    • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
    • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  9. Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 9 中的图像 1,3 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 9 中的图像 2,3 Kodak EasyShare Z1015 IS Back Cover Replacement: 步骤 9 中的图像 3,3
    • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
    • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
结论
2等其他人完成本指南。
katie newman
于10/28/10注册
30 声望
创作了3篇指南
团队
Cal Poly, Team 5-16, Maness Fall 2010 Cal Poly, Team 5-16, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G16
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 1,427
