跳转到主内容
Kodak EasyShare V570 Case Replacement
你所需要的
  1. Kodak EasyShare V570 Case Replacement, Case: 步骤 1 中的图像 1,2 Kodak EasyShare V570 Case Replacement, Case: 步骤 1 中的图像 2,2
    • Here is the front, back, and right side of the camera.
  2. Kodak EasyShare V570 Case Replacement: 步骤 2 中的图像 1,3 Kodak EasyShare V570 Case Replacement: 步骤 2 中的图像 2,3 Kodak EasyShare V570 Case Replacement: 步骤 2 中的图像 3,3
    • There are going to be four #000 screws on the left side of the camera.
    • Remove the four corner screws using a Philips #000 Screwdriver.
    • On the right side of the camera, remove the two Phillips #000 screws at the bottom.
    • On the underside of the camera, remove the three Phillips #000 screws.
  3. Kodak EasyShare V570 Case Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare V570 Case Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare V570 Case Replacement: 步骤 3 中的图像 3,3
    • As soon as all the screws from the casing are removed, use the iFixit opening pick to slide around the border.
    • If the cover appears loose, try to take it off (with your fingers) while slightly wiggling it, and it should detach.
  4. Kodak EasyShare V570 Case Replacement: 步骤 4 中的图像 1,2 Kodak EasyShare V570 Case Replacement: 步骤 4 中的图像 2,2
    • Here is what the camera looks like with both of the covers taken off.
    • The T-W button is upside down.
    • To put the top and back camera covers back on, follow the steps but in reverse.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 92
