跳转到主内容
Kodak EasyShare V570 Battery Replacement
  1. Kodak EasyShare V570 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Kodak EasyShare V570 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Kodak EasyShare V570 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn off your camera before beginning the replacement.
    • Take a finger or two and slide back the compartment where the battery will be and lift it up.
  2. Kodak EasyShare V570 Battery Replacement: 步骤 2 中的图像 1,2 Kodak EasyShare V570 Battery Replacement: 步骤 2 中的图像 2,2
    • Be careful when pulling back the brown tap it can be a little tricky.
    • Push back the brown tab with your finger.
  3. Kodak EasyShare V570 Battery Replacement: 步骤 3 中的图像 1,3 Kodak EasyShare V570 Battery Replacement: 步骤 3 中的图像 2,3 Kodak EasyShare V570 Battery Replacement: 步骤 3 中的图像 3,3
    • Take out the old battery from its compartment with 2 fingers
    • If it doesn't come out that way turn the camera towards you and let it slide out onto your hand.
  4. Kodak EasyShare V570 Battery Replacement: 步骤 4 中的图像 1,2 Kodak EasyShare V570 Battery Replacement: 步骤 4 中的图像 2,2
    • Insert the new battery by pulling down the brown mark.
    • Grab the new battery and insert it into the battery compartment
    • Please do not use force while inserting the new battery.
    • Make sure that the battery has its corner facing down and inwards at the camera.
  5. Kodak EasyShare V570 Battery Replacement: 步骤 5 中的图像 1,3 Kodak EasyShare V570 Battery Replacement: 步骤 5 中的图像 2,3 Kodak EasyShare V570 Battery Replacement: 步骤 5 中的图像 3,3
    • Be careful to not use too much force.
    • Lightly push the cover down and slide it inward.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 91
