当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Lift the screen off the body. Note that it is still connected on one side by the orange tape.
Flip it over gently and let it rest off to the side where the tape is.
It is okay if the orange tape clips out of its spot.
Gently pry up the clip on the top corner to release the metal casing and lift the casing out of the way.
The casing is also connected via an orange tape on the right side that you may leave in place.
Be sure to wear safety glasses while prying the clip.
Find the silver clip where the orange tape from the screen attaches to the circuit board.
Lift up the silver clip. The orange tape will slide out, completely disconnecting the screen from the camera.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
